synop.txt korrekt nur bei 24h Ansicht?
Verfasst: 29 Apr 2006 07:28
von Blauzahn
Guten Morgen,
ich habe folgende Frage:
Ist die erzeugte synop.txt nur in 24h Ansicht korrekt, ich habe die Tagesansicht in WsWin gewählt und die synop.txt gibt den 24h rr nicht korrekt weiter.
Hier die Werte der letzten Tage.
29.04.
06 4.6 3.4 91.8 0 0 1010.9 (-0.9) 7 0.00(24h)
05 4.6 3.3 91.2 0 0 1011.9 (+0.2) 7
04 4.9 3.9 93.2 0 0 1011.9 (+0.2) 7
03 5.7 4.1 89.3 0 0 1011.8 (-0.9) 11
02 6.3 4.8 90.0 0 0 1011.7 (-0.9) 11
01 6.5 4.7 88.1 0 0 1011.7 (-0.0) 0
00 6.7 4.6 86.3 0 0 1012.7 (-0.0) 0
28.04.
23 7.1 4.8 85.1 0 0 1012.6 (-0.0) 7
22 7.3 5.1 85.8 0 0 1013.6 (+0.3) 7
21 7.7 4.7 81.1 0 0 1013.6 (+0.3) 0
20 8.5 4.5 75.7 0 0 1013.5 (+0.3) 4
19 9.3 3.9 68.7 0 0 1013.3 (-0.8) 7
18 9.9 3.7 65.0 0 0 1013.3 (-0.9) 4 2.00(12h)
17 10.9 3.2 58.7 6 0 1013.1 (-0.9) 4
16 11.1 2.9 56.6 0 0 1014.1 (-1.0) 7
15 11.0 2.1 53.8 0 0 1014.2 (-2.2) 14 0.10(3h)
14 11.6 3.2 56.0 0 0 1014.1 (-2.5) 11
13 11.5 2.6 54.0 6 0 1015.1 (-1.5) 11
12 9.8 7.3 84.3 0 0 1016.4 (-1.3) 11 0.40(3h)2.00(6h)
11 8.8 7.9 94.0 0 0 1016.5 (-1.1) 11
10 8.1 7.7 97.3 0 0 1016.6 (-1.1) 7
09 8.0 7.7 98.0 0 0 1017.7 (+0.0) 7 2.00(3h)
08 8.1 7.8 98.0 0 0 1017.7 (+0.1) 11
07 8.0 7.9 99.3 0 0 1017.7 (+1.2) 7
06 8.1 8.0 99.3 0 0 1017.7 (+1.3) 11 2.00(3h)3.0012h3.10 24h)
05 8.5 8.4 99.3 0 0 1017.6 (+1.3) 7
04 8.8 8.7 99.3 0 0 1016.5 (+0.3) 11
03 9.7 9.6 99.3 0 0 1016.4 (-0.8) 18 2.00(3h)
02 10.3 10.2 99.3 0 0 1016.3 (-0.9) 22
01 10.8 10.5 98.0 0 0 1016.3 (-0.0) 14
00 11.4 11.1 98.0 0 0 1017.2 (-0.0) 11
27.04.
23 11.6 11.3 98.0 0 0 1017.2 (-0.0) 11
22 11.8 11.5 98.0 0 0 1017.2 (+0.0) 14
21 11.9 11.5 97.4 0 0 1017.1 (+1.1) 11
20 12.0 11.6 97.4 0 0 1017.1 (+1.1) 11
19 12.0 11.6 97.4 0 0 1017.1 (+1.1) 11
18 12.0 11.7 98.0 0 0 1016.1 (+0.1) 11 0.10(3h)6.00(12h)
17 12.1 11.8 98.0 0 0 1016.1 (+0.1) 14
16 12.2 11.8 97.4 0 0 1016.1 (+0.2) 11
15 12.7 12.1 96.1 0 0 1016.0 (+0.1) 11 0.50(3h)
14 13.1 12.3 94.8 0 0 1015.9 (+0.0) 11
13 13.5 12.4 93.0 0 0 1015.9 (-1.0) 7
12 13.5 12.4 93.0 0 0 1015.9 (-0.1) 11 6.00(6h)
11 13.4 12.3 93.0 0 0 1015.9 (-0.1) 7
10 13.8 12.9 94.3 0 0 1016.9 (+0.8) 14
09 12.8 12.4 97.4 0 0 1016.0 (-0.1) 7 6.00(3h)
08 12.4 12.1 98.0 0 0 1016.0 (-0.0) 7
07 12.1 11.8 98.0 0 0 1016.1 (+0.0) 4
06 12.1 11.8 98.0 0 0 1016.1 (+1.1) 4 0.60(3h)0.80(12h)0.80(24h)
05 12.3 11.9 97.4 0 0 1016.1 (+0.1) 7
04 12.4 12.0 97.4 0 0 1016.0 (+0.1) 4
03 12.7 12.3 97.4 0 0 1015.0 (-1.0) 4 0.10(3h)
02 12.8 12.2 96.1 0 0 1016.0 (-0.0) 0
01 12.8 12.4 97.4 0 0 1016.0 (-0.0) 0
00 12.7 12.3 97.4 0 0 1016.0 (-0.0) 0
Zu sehen ist bei der 6z UTC Meldung, dass der 24h rr nicht korrekt dargestellt wird!
Muss ich zwingend in die 24h Ansicht wechseln oder gibt es einen Trick wie ich korrekte Werte auch in der Tagesansicht erhalte?
Verfasst: 29 Apr 2006 10:57
Hallo Renè,
ich kann dir nur sagen, dass einige Variablen unbedingt die 24h-Anzeige brauchen, um korrekt zu funktionieren. Also gehe ich auch in deinem Fall davon aus. Wenn es anders sein sollte, wird Werner sich sicherlich melden.
Verfasst: 29 Apr 2006 15:15
von Blauzahn
Danke für Dein kurzes Statement.
Mal sehen was der "andere" :wink: Werner dazu meint.
Ich möchte nicht unbedingt in die 24h Ansicht wechseln...
vielleicht gibts ja noch einen Kniff. :)
Verfasst: 29 Apr 2006 16:58
von rolsch
Hallo René,
ich nutze ebenfalls die Synop's.
- jedoch muss hierzu die 24h Ansicht aktiv sein, welche ich sowieso bevorzuge :wink:
Ich sende die Synop's hierhin: http://www.gdhm.de/fr_wir.htm
Verfasst: 29 Apr 2006 17:49
von MichaGreen
Zur korrekten Ermittlung der 24-h-Regenwerte und auch einiger anderer Variablen ist die 24-h-Ansicht erforderlich. Ich habe bzw. zwei Instanzen von WSWin laufen, die eine mit der 24-h-Ansicht, welche dann auch die Synop.txt abarbeitet. Das geht, wenn eine WSWin-Instanz mit der Dateiüberwachung arbeitet.
Grüsse
Michael
