Hier sind die Einträge von 20 Min aus WSWINERR.txt:
22.12.2017 17:05:02.197 V2.98.8 6.2-9200 1 40 0 Read Old: 277 Read New: 278 17:05 22.12.2017 FCount: 0 WCount: 0 ICount: 0
22.12.2017 17:05:06.389 V2.98.8 6.2-9200 1 40 0 ?Upd:16:10 2017/12/22 2017/12/22 2017/01 0
22.12.2017 17:05:06.389 V2.98.8 6.2-9200 1 40 0 ?Upd:16:10 2017/12/22 2017/12/22 2017/02 0
22.12.2017 17:05:06.389 V2.98.8 6.2-9200 1 40 0 ?Upd:16:10 2017/12/22 2017/12/22 2017/03 0
22.12.2017 17:05:06.389 V2.98.8 6.2-9200 1 40 0 ?Upd:16:10 2017/12/22 2017/12/22 2017/04 0
22.12.2017 17:05:06.389 V2.98.8 6.2-9200 1 40 0 ?Upd:16:10 2017/12/22 2017/12/22 2017/05 0
22.12.2017 17:05:06.389 V2.98.8 6.2-9200 1 40 0 ?Upd:16:10 2017/12/22 2017/12/22 2017/06 0
22.12.2017 17:05:06.389 V2.98.8 6.2-9200 1 40 0 ?Upd:16:10 2017/12/22 2017/12/22 2017/07 0
22.12.2017 17:05:06.389 V2.98.8 6.2-9200 1 40 0 ?Upd:16:10 2017/12/22 2017/12/22 2017/08 0
22.12.2017 17:05:06.389 V2.98.8 6.2-9200 1 40 0 ?Upd:16:10 2017/12/22 2017/12/22 2017/09 0
22.12.2017 17:05:06.404 V2.98.8 6.2-9200 1 40 0 ?Upd:16:10 2017/12/22 2017/12/22 2017/10 0
22.12.2017 17:05:06.404 V2.98.8 6.2-9200 1 40 0 ?Upd:16:10 2017/12/22 2017/12/22 2017/11 0
22.12.2017 17:05:06.404 V2.98.8 6.2-9200 1 40 0 ?Upd:16:10 2017/12/22 2017/12/22 2017/12 1
22.12.2017 17:05:06.592 V2.98.8 6.2-9200 1 40 0 MonatSummary: 2017/12 CurMonth:12
22.12.2017 17:05:06.592 V2.98.8 6.2-9200 1 40 0 Set MonthAkt: 16:10 2017/12/22 2017/12
22.12.2017 17:05:10.170 V2.98.8 6.2-9200 1 40 0 MonatSummary: 2017/00 CurMonth:12
22.12.2017 17:05:10.295 V2.98.8 6.2-9200 1 40 0 cT0 template_y.txt -> y2017.html
22.12.2017 17:05:10.311 V2.98.8 6.2-9200 1 40 0 cT0 template_y.txt -> C:\bastide\wetterstation_cham\y2017.html 0
22.12.2017 17:05:10.311 V2.98.8 6.2-9200 1 40 0 cT0 template_noaa_y.txt -> .html
22.12.2017 17:05:10.311 V2.98.8 6.2-9200 1 40 0 cT0 template_noaa_y.txt -> C:\Wswin\noaa2017.txt 0
22.12.2017 17:05:23.156 V2.98.8 6.2-9200 1 40 0 ?Upd:17:04 2017/12/22 2017/12/22 2017/12 0
22.12.2017 17:05:23.172 V2.98.8 6.2-9200 1 40 0 MonatSummary: 2017/12 CurMonth:12
22.12.2017 17:05:23.187 V2.98.8 6.2-9200 1 40 0 cT0 template_m.txt -> m20171217.txt
22.12.2017 17:05:23.187 V2.98.8 6.2-9200 1 40 0 cT0 template_m.txt -> C:\Wswin\m20171217.txt 0
22.12.2017 17:05:23.187 V2.98.8 6.2-9200 1 40 0 cT0 template_noaa_m.txt ->
22.12.2017 17:05:23.203 V2.98.8 6.2-9200 1 40 0 cT0 template_noaa_m.txt -> C:\Wswin\noaa201712.txt 0
22.12.2017 17:05:27.532 V2.98.8 6.2-9200 1 40 0 W1: xJMW 22.12.2017 KW:51
22.12.2017 17:05:27.657 V2.98.8 6.2-9200 1 40 0 cT0 template_w.txt -> m20171217.txt
22.12.2017 17:05:28.423 V2.98.8 6.2-9200 1 40 0 cT0 template_w.txt -> C:\Wswin\m20171217.txt 1
22.12.2017 17:05:32.677 V2.98.8 6.2-9200 1 40 0 Read Old: 114 Read New: 278 17:05 22.12.2017 FCount: 0 WCount: 0 ICount: 1
22.12.2017 17:05:33.255 V2.98.8 6.2-9200 1 40 0 c0 custom.txt -> custom.html
22.12.2017 17:05:36.271 V2.98.8 6.2-9200 1 40 0 c0 custom.txt -> c:\bastide\wetterstation_cham\custom.html
22.12.2017 17:05:36.287 V2.98.8 6.2-9200 1 40 0 c1 wap.txt -> data.txt
22.12.2017 17:05:36.318 V2.98.8 6.2-9200 1 40 0 c1 wap.txt -> c:\data.txt
22.12.2017 17:05:36.318 V2.98.8 6.2-9200 1 40 0 cT0 template_d.txt -> dayx.txt
22.12.2017 17:05:36.318 V2.98.8 6.2-9200 1 40 0 cT0 template_d.txt -> C:\Wswin\day5.txt 0
22.12.2017 17:06:28.000 V2.98.8 6.2-9200 1 40 0 2017-12-22+16:05 -> WG
22.12.2017 17:10:02.448 V2.98.8 6.2-9200 1 40 0 Read Old: 278 Read New: 279 17:10 22.12.2017 FCount: 0 WCount: 0 ICount: 0
22.12.2017 17:10:06.454 V2.98.8 6.2-9200 1 40 0 c0 custom.txt -> custom.html
22.12.2017 17:10:37.138 V2.98.8 6.2-9200 1 40 0
http://api.weathercloud.net - no answer
22.12.2017 17:10:39.732 V2.98.8 6.2-9200 1 40 0 c0 custom.txt -> c:\bastide\wetterstation_cham\custom.html
22.12.2017 17:10:39.748 V2.98.8 6.2-9200 1 40 0 c1 wap.txt -> data.txt
22.12.2017 17:10:39.779 V2.98.8 6.2-9200 1 40 0 c1 wap.txt -> c:\data.txt
22.12.2017 17:10:39.779 V2.98.8 6.2-9200 1 40 0 cT0 template_d.txt -> dayx.txt
22.12.2017 17:10:39.779 V2.98.8 6.2-9200 1 40 0 cT0 template_d.txt -> C:\Wswin\day5.txt 0
22.12.2017 17:11:27.991 V2.98.8 6.2-9200 1 40 0 2017-12-22+16:10 -> WG ÿ
22.12.2017 17:15:02.087 V2.98.8 6.2-9200 1 40 0 Read Old: 279 Read New: 280 17:15 22.12.2017 FCount: 0 WCount: 0 ICount: 0
22.12.2017 17:15:06.199 V2.98.8 6.2-9200 1 40 0 c0 custom.txt -> custom.html
22.12.2017 17:15:37.132 V2.98.8 6.2-9200 1 40 0
22.12.2017 17:15:39.398 V2.98.8 6.2-9200 1 40 0 c0 custom.txt -> c:\bastide\wetterstation_cham\custom.html
22.12.2017 17:15:39.398 V2.98.8 6.2-9200 1 40 0 c1 wap.txt -> data.txt
22.12.2017 17:15:39.445 V2.98.8 6.2-9200 1 40 0 c1 wap.txt -> c:\data.txt
22.12.2017 17:15:39.445 V2.98.8 6.2-9200 1 40 0 cT0 template_d.txt -> dayx.txt
22.12.2017 17:15:39.445 V2.98.8 6.2-9200 1 40 0 cT0 template_d.txt -> C:\Wswin\day5.txt 0
22.12.2017 17:20:02.078 V2.98.8 6.2-9200 1 40 0 Read Old: 280 Read New: 281 17:20 22.12.2017 FCount: 0 WCount: 0 ICount: 0
22.12.2017 17:20:06.020 V2.98.8 6.2-9200 1 40 0 c0 custom.txt -> custom.html
22.12.2017 17:20:37.128 V2.98.8 6.2-9200 1 40 0
22.12.2017 17:20:39.191 V2.98.8 6.2-9200 1 40 0 c0 custom.txt -> c:\bastide\wetterstation_cham\custom.html
22.12.2017 17:20:39.191 V2.98.8 6.2-9200 1 40 0 c1 wap.txt -> data.txt
22.12.2017 17:20:39.222 V2.98.8 6.2-9200 1 40 0 c1 wap.txt -> c:\data.txt
22.12.2017 17:20:39.222 V2.98.8 6.2-9200 1 40 0 cT0 template_d.txt -> dayx.txt
22.12.2017 17:20:39.238 V2.98.8 6.2-9200 1 40 0 cT0 template_d.txt -> C:\Wswin\day5.txt 0
22.12.2017 17:21:27.994 V2.98.8 6.2-9200 1 40 0 2017-12-22+16:20 -> WG ÿ
22.12.2017 17:25:02.094 V2.98.8 6.2-9200 1 40 0 Read Old: 281 Read New: 282 17:25 22.12.2017 FCount: 0 WCount: 0 ICount: 0
22.12.2017 17:25:06.268 V2.98.8 6.2-9200 1 40 0 c0 custom.txt -> custom.html
22.12.2017 17:25:37.153 V2.98.8 6.2-9200 1 40 0
22.12.2017 17:25:39.497 V2.98.8 6.2-9200 1 40 0 c0 custom.txt -> c:\bastide\wetterstation_cham\custom.html
22.12.2017 17:25:39.497 V2.98.8 6.2-9200 1 40 0 c1 wap.txt -> data.txt
22.12.2017 17:25:39.544 V2.98.8 6.2-9200 1 40 0 c1 wap.txt -> c:\data.txt
22.12.2017 17:25:39.544 V2.98.8 6.2-9200 1 40 0 cT0 template_d.txt -> dayx.txt
22.12.2017 17:25:39.544 V2.98.8 6.2-9200 1 40 0 cT0 template_d.txt -> C:\Wswin\day5.txt 0
22.12.2017 17:26:28.979 V2.98.8 6.2-9200 1 40 0 2017-12-22+16:25 -> WG ÿ
Gruss Hans
