TFA Nexus to Wunderground
Verfasst: 17 Mär 2018 10:44
von Bob G
Hi, I have a TFA Nexus weather station running pc-wetterstation software. I update Wunderground, but it only updates every hour. Is it possible to update Wunderground more frequently? I have tried numerous settings but nothing seems to make any difference.
Any help will be great. Thanks in advance.
Bob
Verfasst: 17 Mär 2018 10:55
Hello,
have you already tried "Internet - adjustments - wunderground" and there "Transfer data like FTP"?
Verfasst: 17 Mär 2018 11:06
von Bob G
Hi Werner, yes it is on Transfer Data Like FTP now, but it is only uploading data every hour. Can I change the frequency of uploads in the settings?
Bob
Verfasst: 17 Mär 2018 12:03
Hello,
I see no other "normal" way"
Verfasst: 17 Mär 2018 12:17
not "Data Like FTP"
but one under them: "Zeitsteuerung 2 Extra" ("time control 2 extra"?)
You must configure under: >file >options >time control 2 extra
@Werner: ich hab nur die deutsche Version drauf, weshalb die ich die engl. Bezeichnungen "frei Schnauze" übersetzt habe. Wenn das so nicht stimmt, bitte berichtigen.
Verfasst: 17 Mär 2018 13:03
Try to use "Time controlling 2:Extra"
to find also under "Internet Adjustments - Wunderground.com "
But, to be honest, I don't know, what to fill in there to use Wunderground
Verfasst: 18 Mär 2018 09:11
von Bob G
Hi,
I have fixed the problem - I did not have Control > Adjustments > Transfer set up correctly. My station is now reporting every 5 minutes :D
Thank you both for your help.
Bob
