Sensorstatus - Telemetrie
Verfasst: 29 Jul 2025 20:26
Es existieren noch 2 weitere Sensoren, wie kann man die noch hinzufügen?
[<div] id="history_day" class="plot_containter" style="display: block;">
<img src="dayvoltage1.png" alt="soilMoistBatt1">
<img src="dayvoltage2.png" alt="soilMoistBatt3">
</div>]
Re: Sensorstatus - Telemetrie
Verfasst: 30 Jul 2025 10:59
Die entsprechenden Einträge sind in der
telemetry.html.tmpl
zu machen und natürlich via skin.conf auch erzeugt werden!:
Meine Einträge aktuell dazu:
#for $x in [
{'data': $period.rxCheckPercent, 'img': 'rx', 'alt': 'signal'},
{'data': $period.signal2x, 'img': 'rx1', 'alt': 'signal2'},
{'data': $period.signal5x, 'img': 'rx2', 'alt': 'signal5'},
{'data': $period.signal3x, 'img': 'rx3', 'alt': 'signal'},
{'data': $period.signal4x, 'img': 'rx4', 'alt': 'signal'},
{'data': $period.signal5x, 'img': 'rx5', 'alt': 'signal'},
{'data': $period.signal6x, 'img': 'rx6', 'alt': 'signal'},
{'data': $period.signal7x, 'img': 'rx7', 'alt': 'signal'},
{'data': $period.signal8x, 'img': 'rx8', 'alt': 'signal'},
{'data': $period.consBatteryVoltage, 'img': 'volt', 'alt': 'voltage'},
{'data': $period.heatingVoltage, 'img': 'volt', 'alt': 'voltage'},
{'data': $period.supplyVoltage, 'img': 'volt', 'alt': 'voltage'},
{'data': $period.referenceVoltage, 'img': 'volt', 'alt': 'voltage'},
{'data': $period.windBatteryStatus, 'img': 'volt', 'alt': 'voltage'},
{'data': $period.soilMoistBatt1, 'img': 'voltage1', 'alt': 'soilMoistBatt1'},
{'data': $period.soilMoistBatt2x, 'img': 'voltage1x', 'alt': 'soilMoistBatt2'},
{'data': $period.soilMoistBatt3, 'img': 'voltage2', 'alt': 'soilMoistBatt3'},
{'data': $period.rainBatteryStatus, 'img': 'voltage3', 'alt': 'rainBatteryStatus'},
{'data': $period.ws85cap_volt, 'img': 'voltcap', 'alt': 'ws85cap_volt'},
{'data': $period.pb, 'img': 'heap0', 'alt': 'Heap'},
{'data': $period.ldsheat_ch1, 'img': 'lds_heat', 'alt': 'ldsheat_ch1'},
{'data': $period.wh31_ch3_rssi, 'img': 'rssi_wh31', 'alt': 'wh31_ch3_rssi'},
{'data': $period.wh32_ch1_rssi, 'img': 'rssi_wh32', 'alt': 'wh32_ch1_rssi'},
{'data': $period.wn34_ch1_rssi, 'img': 'rssi_wn341', 'alt': 'wn34_ch1_rssi'},
{'data': $period.wn35_ch1_rssi, 'img': 'rssi_wn35', 'alt': 'wn35_ch1_rssi'},
{'data': $period.wh51_ch1_rssi, 'img': 'rssi_wh511', 'alt': 'wh51_ch1_rssi'},
{'data': $period.wh51_ch9_rssi, 'img': 'rssi_wh512', 'alt': 'wh51_ch9_rssi'},
{'data': $period.wh55_ch1_rssi, 'img': 'rssi_wh55', 'alt': 'wh55_ch1_rssi'},
{'data': $period.ws85_rssi, 'img': 'rssi_ws80', 'alt': 'ws85_rssi'},
