VP2 Firmware 3.12
Verfasst: 20 Mai 2013 13:25
Hallo Wetterfreunde!
Es gibt für die VP2 bereits die Fimware Version 3.12
Hier die Links:
cabled: http://www.davisnet.com/support/weather ... wareID=230
wireless: http://www.davisnet.com/support/weather ... wareID=223
Version History
Firmware version 3.12
- Fixed a bug in 3.00 that did not allow the ET alarm to be cleared.
- Eliminates occasional WeatherLink communication issue when console is busy receiving a radio packet.
Firmware version 3.00
- Console times out of the "Receiving From" setup screen after 15 minutes using batteries and 30 minutes using AC power.
- Previous versions of firmware allowed a negative ET, now it will clip hourly ET values at 0.
- Added leading zero to temp readings between -1.0 and 1.0.
- Improved temp and hum index calculations.
- Low humidity readings now clipped at 1% and will not show 0%.
Firmware version 1.90
- CWOP uploads will now contain 2 min average wind speed, 10 min wind gust and direction of gust, last 15 minutes of rain, last 1 hour of rain and Altimeter. Must also have WeatherLink software v5.9.0 or later to use this feature.
- Fixed a bug that caused the barometer value to have a large error after updating to firmware version 1.82
Before You Install
IMPORTANT! This firmware is only for Vantage Pro2 Cabled Consoles manufactured April 2006 or later (#6312C, #6312COV, #6312CUK, #6312CEU). The Inside Temp, Inside Hum, and Barometer readings will not appear if 3.12 firmware is installed on consoles manufactured before April 2006.
Vorsichtige Anfrage an Werner: wird es diese irgendwann auch wieder auf Deutsch geben?
Danke!
Hier die Links:
Version History
Before You Install
Danke!
