Bugs in wswin32 2.93.5 with Davis VP2
Arcibald
Beitrag von Arcibald »
Hi,
Found bug in wswin 2.93.5, with it I use of 2 sensors temperature the Tmax is always equal
Regards
Danksagung erhalten: 147 mal
Hello,
please can you show your Min./Max table
Create it:
Select View, Minimum and maximum...
double click in the table
a file minmax_yyyymmdd.gif will be created.
Arcibald
Error in Tmax
Error in Tmax
Error in Tmin
Error in Tmax
:cry: :cry:
@Arcibald,
I can't find any incongruity.
On some days the Tmin is equal, on other days the Tmax is equal.
Arcibald
Excuse but for me there is a bug in the software :cry:
Here there are the values read from the sensors and are different !!
http://www.meteopiateda.it/Piateda/PC/20061016.htm
Best regards
Hello
the table shows the same values - so where is is the difference?
Arcibald
Hello,
The difference is that the Tmax recorded to 2 meters it is not 19.3° to the 13,54, but 18.9° recorded to the 13,32. An error of software in bringing back is obvious therefore such data.
Martin
What is your dew point sensor?
It seems that you use for dew point (= main outdoor sensor)
the sensor "Temperatura esterna 10 m"
So it is correct.
Arcibald
Hello Werner
In quarter column of http://www.meteopiateda.it/Piateda/PC/20061016.htm ( T.Est 2m.) I never do not see 19.3°C unless in “massima” line.
It is mistaken because the tmax 2m of the 16/10/2006 it is 18.9°C.
The timetable of the "Max-Ora" (2m sensor) is mistaken because the Tmax 2m it has been recorded to the 13,32.
Martin
@Martin,
I didn't assume that someone uses for
main outdoor temperature a second (extra) temperature sensor,
which isn't so accurately and has a only resolution of ~0.5 °C
You are right, Wswin merges the min/max values from the
standard outdoor sensor to this sensor.
I will correct that.
Arcibald
Werner hat geschrieben:@Martin,
It does not appeal to not even me this solution, but in order not to leave in shadow the solar sensors, I have had to install the iss on the house roof and to put an extra sensor in garden.
Thank you.
Martin
