Last rain
Ryant
Last rain
Beitrag von Ryant »
When I look at the last rain recorded, it always shows the last few minutes as a time (and under statistics), but nothing recorded. Is there a way for the actual last rain to show instead. See http://www.cumbriawx.org.uk/current.html.
Thanks guys.
Helo,
perhaps you try the following:
"weather - weatherforecast - statistic dates" and there press the button "reset" at last rain.
Then go back and choose "View - year"
Afterwards it should bei all right.
Ryant
Beitrag von Ryant »
Thanks Werner, I tried that but it keeps returning to the last minute.
Hello,
I've no idea for the moment. Perhaps Werner can help you. But you should correct your link, there is a dot at the end, so it doesn't work.
correct
Hello,
one more idea to try:
- do the same as I have already told you and then:
- "internet - update Graphics/Tables" and there set a hook at "Dryness Icedays Time" and "year file"
Then choose the whole year for actualisation. I hope, it will work.
Ryant
Beitrag von Ryant »
Hello again,
I've tried what you suggested, but it's still the same. It's been there on all versions of WsWin but can't get rid of it.
Thanks anyway.
Ryan.
Danksagung erhalten: 147 mal
@Ryan,
it think you set at
Weather station, Special sensors, #3
and here at Time sensor a wrong sensor or a wrong value.
Or disable there "Pricipitation strength".
Ryant
Beitrag von Ryant »
Thanks Werner, I had "Pricipitation strength" ticked. Removing that has now corrected everything.
Cheers for your help.
Ryan
