Wind correction.
Ryant
Wind correction.
Beitrag von Ryant »
Hi, I recently got this great program but am confused with the wind correction. I need to build in a 10% correction increase on actual wind speeds and gusts (due to where I have sited the equipment). Do I enter a figure in the first box or the second next to the +/- uncer file-properties?
Thanks for any help.
Ryan
Hello,
you do it in the first box.
The second box is for a constant value, that means, when you enter "20" in the second box, there will always be entered "20" and not per centage
Correction:
not "there will always be entered" but "there will always be added"
Zuletzt geändert von weneu am 08 Feb 2007 22:51, insgesamt 1-mal geändert.
@Ryan
enter there at
Sensor calibration x 1.100
(for 10% more)
at +/- 0.00
Ryant
Beitrag von Ryant »
Thanks for your help guys, so entering 0.10 in the first box will increase the wind recorded by 10%, and I should leave the second +/- box as 0.00.
Hello,
yes, but you must enter 1,10 and not 0,10
Ryant
Beitrag von Ryant »
Ok, thanks very much.
