Hello
Sometime when I start wswin there is no readings from the station, it´s completly blank. Now I have found why, wswin is getting the wrong time from the station. In the statebar it says "TE923: time" and it´s 12 hours wrong. I don´t think this is a wswin error because if I set the time on the station the statebar shows the right time. But i´m wondering if there is a way to "reset" wswin readouts so that I can start a new readout from the station with the right time?
Irox time
@Dan,
you can do that under Weather station, Adjustments and here
"Reset Record Pointer" (only if Recording stopped).
But you will not have success if the date/time in the station and on the pc are not equal.
A other problem is: in each data set from the station the date/time is stored and if they are wrong, the software don't take over this.
The software only allows newer data sets and no data sets in the future.
