soil sensor tags return -- values
wvdkuil
Beitrag von wvdkuil »
As my German is far worse then my English, I will post this question in English.
These are the sensor names I use:
|soilTempAct[1]|                %curval[13]%|!
|soilTempMax24h[1]|             %maxval[13]%|!
|soilTempMax24hTime[1]|         %ws_date%T%maxtime[13]%|!
|soilTempMaxToday[1]|           %curminmaxhour[2,0,13]%|!
|soilTempMaxTodayTime[1]|       %ws_date%T%maxtimecurday[13]%|!
|soilTempMaxMonth[1]|           %ws_m_maxval[%ws_month%,13]%|!
|soilTempMaxMonthTime[1]|       %ws_m_maxday[%ws_month%,13]%T%ws_m_maxtime[%ws_month%,13]%|!
|soilTempMaxYear[1]|            %ws_m_maxval[0,13]%|!
|soilTempMaxYearTime[1]|        %ws_m_maxday[0,13]%T%ws_m_maxtime[0,13]%|!
|soilTempMin24h[1]|             %minval[13]%|!
|soilTempMin24hTime[1]|         %ws_date%T%mintime[13]%|!
|soilTempMinToday[1]|           %curminmaxhour[1,0,13]%|!
|soilTempMinTodayTime[1]|       %ws_date%T%mintimecurday[13]%|!
|soilTempMinMonth[1]|           %ws_m_minval[%ws_month%,13]%|!
|soilTempMinMonthTime[1]|       %ws_m_minday[%ws_month%,13]%T%ws_m_mintime[%ws_month%,13]%|!
|soilTempMinYear[1]|            %ws_m_minval[0,13]%|!
|soilTempMinYearTime[1]|        %ws_m_minday[0,13]%T%ws_m_mintime[0,13]%|!
These are the values returned, only actual and today values are returned.
|soilTempAct[1]|                12.8|!
|soilTempMax24h[1]|             13.3|!
|soilTempMax24hTime[1]|         20150602T19:20|!
|soilTempMaxToday[1]|           12.8|!
|soilTempMaxTodayTime[1]|       20150602T00:00|!
|soilTempMaxMonth[1]|           --|!
|soilTempMaxMonthTime[1]|       --T--|!
|soilTempMaxYear[1]|            --|!
|soilTempMaxYearTime[1]|        --T--|!
|soilTempMin24h[1]|             12.2|!
|soilTempMin24hTime[1]|         20150602T11:25|!
|soilTempMinToday[1]|           12.2|!
|soilTempMinTodayTime[1]|       20150602T11:25|!
|soilTempMinMonth[1]|           --|!
|soilTempMinMonthTime[1]|       --T--|!
|soilTempMinYear[1]|            --|!
|soilTempMinYearTime[1]|        --T--|!
I tried to find a solution in the manual, but I can not find it.
Wim
Hello,
there must be something else wrong, because the variables are OK and I get these values:
soilTempAct[1]| 26,1|! |soilTempMax24h[1]| 36,7|! |soilTempMax24hTime[1]| 03.06.2015T11:40|!
|soilTempMaxToday[1]| 36,7|!
|soilTempMaxTodayTime[1]| 03.06.2015T11:40|!
|soilTempMaxMonth[1]| 36,7|!
|soilTempMaxMonthTime[1]| 03.06.2015T11:40|!
|soilTempMaxYear[1]| 36,7|!
|soilTempMaxYearTime[1]| 03.06.2015T11:40|!
|soilTempMin24h[1]| 12,8|!
|soilTempMin24hTime[1]| 03.06.2015T06:05|!
|soilTempMinToday[1]| 12,8|!
|soilTempMinTodayTime[1]| 03.06.2015T06:05|!
|soilTempMinMonth[1]| 12,2|!
|soilTempMinMonthTime[1]| 02.06.2015T00:45|!
|soilTempMinYear[1]| -10,6|!
|soilTempMinYearTime[1]| 04.02.2015T07:00|!
If you like, you can send me the File and I shall have a look at it.
w.neudeck@web.de
Call it "variables"
Danksagung erhalten: 149 mal
@Wim,
select once Year view
and you get filled this variables.
Those variables (ws_m_...) are only updated
when the graphics view is/was Year.
Better use the much newer variables or
verify (compare) with
%ws_getmem_year%
wvdkuil
Werner hat geschrieben:@Wim,
%ws_getmem_year%
I also checked as I thought I forgot to set once the view to year after a total black-out. seems to be the case.
At the moment it is not clear how to use the variables you are refering, but I will certainly study / try to find what you mention. But the new template release is going public at 15 June. So I can not change anything as I do not know if current users are up to date with their WSWIN release.
The new release looks promising http://weather-template.nl/weather27/in ... g=en&wp=WS
The WSWIN program also scores high on the comparison page at: http://leuven-template.eu/dokuwiki27/do ... d=en:facts
Wim
@Wim
for example:
use
%maxval_mpast[13~%ws_month2%~%ws_year%]%
or %maxval_mpast[13~%ws_month2%~0000]%
