custom.html
For englisch users
Moderators: Tex, weneu
Post Reply
Hold78
custom.html
Post by Hold78 »
I have one question. I want to create custom.html, but i have problem with that. In internet-adjustments-common I have checked update customized Html files in recording mode and in tab current.html I have unchecked create symbolic weather file in recording mode.
In C:\Wswin\html I had only current.html at first. There is no file current_.txt. Then I have opened current.html in Notepad and rename it in custom and save as a txt document. (also in first line of documnet i have put <customfile>). But nothing happened after all. WsWin generate current.html automatically again and again.
Any help would be appreciated,
Dankeschön
User avatar
Been thanked: 161 times
Contact:
Post by Werner »
Hi,
you should use current_en.txt and rename this file to custom.txt
With this (inside current_en.txt)
<!-- %customfile=current.html% -->
a current.html file will be created.
Hold78
Post by Hold78 »
I have done this but is still the same. I have copied current_en.txt from local C / Wswin into html folder. Then rename this file into custom.txt and used this code in first line. But Wswin still generate their own current file continuosly.
User avatar
Contact:
Post by Werner »
That's wrong!
copy it to C:\Wswin (and not to C:\Wswin\html )
Hold78
Post by Hold78 »
Thats work :) Vielen Dank Werner :D
Noch eine Frage bitte :wink:
Do you know why gif images do not appear on my website and why these weird characters appear?
User avatar
Contact:
Post by Werner »
Did you upload this gif's to your homepage-weather-folder ?
characters: wrong charset set
or your site supports only UTF-8 (so change to this charset)
Hold78
Post by Hold78 »
I will check this. Thanks a lot ! :D
Post Reply
