Hello, I have problems again ...
My 3-year old nephew pressed some button(s) on the keyboard of the computer that runs wswin ... Computer shuted down and when I started it again and tried to open wswin's shortcut it says that shortcut that runs wswin32.exe has been changed and or moved ... So now I can't find wswin32.exe nowhere in the computer ...
I tried to restored computer to 1 day prior to this accident, but the situation stayed the same - there is no working shortcut or existitng wswin32.exe ...
What can I do to get access to wswin? Please help.
Lost wswin.exe
- Been thanked: 138 times
- Contact:
Re: Lost wswin.exe
Hi,
if you are a registered User of Wswin simple download the registered Version.
You need the former send access data to enter the secured folder for the registered Users.
So don't download the Test version!
Re: Lost wswin.exe
Thank you for the answer, but WHERE from can I download the full/registered version of wswin (I am registered user)? Can you please send me the link?
- Been thanked: 18 times
- Contact:
Re: Lost wswin.exe
Hello,
you can download it from
https://www.pc-wetterstation.de/user
but for login you need your username and password. If you have lost it, you have to sende a Mail to Werner Krenn
Re: Lost wswin.exe
What should I do next to get all older data to this new wswin (folder)? I copied folder "all data" to new wswin folder and nothing happened ... Is there any option to get old settings to the new folder? I am completely lost ...
- Contact:
Re: Lost wswin.exe
Simple copy all w*.dat files from the old Computer (or folder)
to the new Computer (or folder) into the folder C:\Wswin
Re: Lost wswin.exe
It was enough only to copy wswin.CFG to new folder and everything is like before problems (on the old wswin folder).
Thanks!
Thanks!
