Ver 2.79.1 Sun/Moon
Marc
Beitrag von Marc »
Hi Werner,
Thanks for the new possibilities in this version. I noted in the tab Sun/Moon that there is never a day, just the hour, the month and the year. This is true for the tabs Data, more and moon. And as you are there, a small mistake also in the naming of twilight: is named twinlight 3 times.
As always, nothing important, everything runs smoothly and that is important.
Bye,
Marc
Danksagung erhalten: 138 mal
Hi Marc,
what long Date format do you use?
I have no selection for "Belgium" in my Windows enviroment.
For Germany, this format is like this
"DDDD, D. MMMM YYYY"
If you have no "D." -> day ... (in your long date format)
that can be the reason.
.. used is only the string after "," for showing the date.
For example here 22. April 2002 (for Germany)
or for English "DDDD, MMMM DD, YYYY" -> Tuesday, April 22, 2002, but there is only
"MMMM DD, YYYY" used.
So you can correct it by yourself.
Marc
Beitrag von Marc »
Good morning Werner,
Sorry to have bothered you. Everything is just fine now after your explanation.
Thanks a lot.
Marc
