WS3600 / No communication > PC
PH3V
Beitrag von PH3V »
Bought this weatherstation last week. Test it using Heavyweather Pro 3600.
(Packed with the station) No problems so far. Good serial communication. All info shows up on the screen. Great... but.......
When i try PC-Wetterstation - V2.91.2 - no communication/connection with my PC is possible. All values stays blank/0/0.0 etc.
I tried many many things, but still without luck. :?
Settings:
PC Port settings: 9600 8N1 Com 1
Tried USB-Serial adapter on COM2, no success.
Interface type: WMR-918/928/968
no mark at: without interface, so the interface is enabled.
I filled in my home location. Long/Lat (essential i read)
Who's got i brilliant idea? :)
PS, You may answer in German.. easy to read hard to write :wink:
@PH3V,
WsWin can't direct communicate with the WS3600.
You need to use the function "File-Watching"
PH3V
Beitrag von PH3V »
TNX Werner! ... I forgot to RTFM :oops: ... :wink:
Things work fine for now.
Was suprised to see the WX history on the screen! Great!
Now learning the many other options.
Will buy it soon.
