m/s instead of km/h or bft
kulfsson
Beitrag von kulfsson »
Hi,
i just purchased this software and I am working on getting a website in the air. I have run into a small problem in that I cannot seem to get the wind displayed in m/s. In my country we do not use km/h or bft so I want to get all the wind speeds in m/s. is this possible ?
Also I was wondering if anyone has a link to templates I can use as ideas for my own ? It doesn´t matter if it is freeware or shareware.
Hope you can help. You can also answer in German if you want. I can read it but I am not so good at writing it ;-)
Vielen dank,
Kristjan Ulfsson
@Kristjan,
goto File, Properties
select the Wind Sensor (and/or Wind Gust Sensor )
and here choose the "Unit" which you prefer.
Here you can also set a own description for the measurements.
Leave this window with "OK".
Example: look in the Wswin installation folder for
current_en.txt (there are others too)
