Speech setup
For englisch users
Moderators: Tex, weneu
Post Reply
CurtisZM
Contact:
Speech setup
Post by CurtisZM »
Werner,
I didn't find any Speech setup guidance in the Help. Do you have a guide anywhere?
I've installed the speech programs. Setup speech to what I think is what it should be. Looks like WS created the ws-speech.wav file in the WSWIN root directory. Settings are set to create a new wav file every hour.
The ws_speech.wav file is not updating . When I first setup Speech, the file was create once and that was it.
Please assist. Thank you.
User avatar
Been thanked: 146 times
Contact:
Post by Werner »
@Curtis,
I use the customising - so I need the ws_speech.txt file
CurtisZM
Contact:
Speech
Post by CurtisZM »
Werner,
I cannot change the Wave <..>ws_speech.txt. It is greyed out.
User avatar
Contact:
Post by Werner »
@Curtis
So you have no such file.
You can rename the example "German" ws_speech_.txt file
to ws_speech.txt and then modify it.
But you needn't at starting a customised speech file!
CurtisZM
Contact:
@werner
Post by CurtisZM »
Here is a picture of my settings. I got it from being greyed out. Can I use True Voice or no? Thank you.
Image[/img]
Post Reply
